Old 01-02-2010, 09:57 AM   #1
Furnace Problems
I have a lennox G40 Merit series that I noticed yesterday that it is experiencing a no light condition. I heard the fan come on and then the burners came on but it would shut down without lighting. It did this a couple of times and the two led lights inside where flashing quickly. I have changed out the board a few years ago, and I can't remember if this problem was the problem back then. But any suggestions would be greatly appreciated.
swoop is offline   Reply With Quote
Old 01-02-2010, 10:31 AM   #2
Hvac Pro
Furnace Problems
Sequence of operation:
1) Inducer fan comes on over the burners
2)Igniter glows red hot by right burner
3)Burners light and main fan comes on
Is the igniter glowing? burners lighting and then going out? If so clean the flame sensor with fine emory paper or steel wool. Sits in front of one of the burners and should look like this:
Old 01-02-2010, 11:01 AM   #3
Furnace Problems
I do believe it is. Unfortunately I'm at work, so I hope it doesn't go south while I'm gone. But I will clean the flame sensor tommorrow.
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
Problems With Gas Valve-Old Iron Core Furnace HAVCN HVAC 6 03-02-2009 05:52 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
Carrier 58MXA furnace problems bush HVAC 5 12-12-2007 09:42 PM
