Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 02:38 PM   #1
furnace problem
have electric forced air furnace, only blows cold air, have checked cir breakers.
Walt Duvall is offline   Reply With Quote
Old 12-11-2010, 06:43 PM   #2
Time to call a pro walt. If you have to ask how to check high voltage circuits then it's beyond DIY.
Old 12-12-2010, 02:07 AM   #3
Thats a big 10-4 Big Bird.
hvaclover is offline   Reply With Quote
Old 12-12-2010, 08:36 AM   #4
An old Tradesmen
Rewards Points: 7,312
This could be a control problem. Or a problem with the elements themselves.
To check the control circuit, often requires you to move a multimeters probes and or your hands close to the line voltage circuits, where a wrong contact with the probe could fry your control system, and or you.
If you can give a better idea of your abilities. You may get help. If your not comfortable with your hands being close to 240 volts. You may want a contractor to come out and diagnose and fix it for you.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
