Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 11:38 AM   #1
Furnace problem
I have a Heil high efficiency unit single stage. was blowing cold air. went to check it and it had no fire. I reset power and turned off gas for 5 min. tried to turn on again. fire went on for a couple minutes then turned and started blowing cold air again??????????
Jimmy Sr. is offline   Reply With Quote
Old 11-28-2010, 12:18 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Have you checked and or replaced your filter recently? Also there should be a viewing window in one of the doors to check a led for a trouble (flash) code.
hvactech126 is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
problem with Furnace staying on. rdavis HVAC 4 12-01-2009 09:19 PM
Help - Problem with Oil Fired Forced Air Furnace JohnF HVAC 13 01-31-2009 09:04 PM
