Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 10:52 PM   #1
Question
Furnace problem
My ComfortMaker furnace has 4 burners. The end one is where the flame sensor is. When the furnace starts 3 of the burners have a nice blue flame but the 4th one (where the sensor is) has no flame at all. So gas is getting to the burners but the end one has no gas going to it. How do I fix this problem? Can I take out the burner assembly and clean it? How do I do that? Thank you.
Louie
Louis Tafoya is offline   Reply With Quote
Old 10-13-2008, 08:10 AM   #2
biggles's Avatar
they should all come out seperate with the header staying in place from the gas valve.push the burner foward and lift it on the header there should be a brass fitting which is the orifice for that chamber burner.you have 4 burners each has an orifice to feed the gas into the burner runout.probably a bug fell asleep in there they like the scent of nat.gas...take a small adjustable wrench or a box end,and remove the orifice....... lefty losey........righty tighty.normal piping threads put the wrench on it "bump it" and finger loosen it out.watch the air inlet adjuster(where the orifice sticks into) when you grab the burner to pop it out it might not be screwed down,and moves adjust it as others on reinstall...with flames running
Old 10-13-2008, 01:14 PM   #3
Thank you biggles
I took out the orifice and sure enough it was plugged. Not a spider but just junk. Cleaned it and it is now working like it should. Thank you so much for your help! It is so great to not have to call a service repairman for such a minor and easy fix. You saved me at least $80, thanks again.
Old 10-13-2008, 05:00 PM   #4
biggles's Avatar
thats cool...keep an eye on the other burners see if the others start to move around.the actual burner flame is the heat rating of your furnace so the true'r they burn (4 jets)the better heating you will achive.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 11:13 AM
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 08:36 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 07:53 AM
furnace problem captjack HVAC 8 11-23-2007 11:15 AM
