Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 09:49 AM   #1
furnace problem
Hi folks,
I have an oil furnace with 3 zones using forced hot water to heat my house.I have noticed when the furnace runs to maintain the domestic water temp,hot water is forced up through the 1st floor baseboard even when the heat is not called for in the house.What would cause the hot water to be forced up through the baseboard? I have noticed a drop in my pressure due to a leaky coil gasket but it usually holds approx 10-12 psi.I also have a lot of bubbling sounds on the 2nd and 3rd floor zones when the heat comes on.Air in the lines I assume, but would any of these cause the problem?There is also an expansion tank just before the 3 zones split off to each floor.Could this be faulty and causing my problem? The furnace is 20 years old also.
Any help is greatly appreciated,
Ray
raypan is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
