Old 02-12-2012, 10:30 AM   #1
furnace prob
i have a coleman funace 2yrs old and its telling me i have a pressure switch stuck open what do i do to fix i need to fix it asap its cold my kids are freezing can anyone help me
ronjon159 is offline   Reply With Quote
Old 02-12-2012, 10:51 AM   #2
furnace prob
Pressure switch is stuck open? Check your exhaust fan make sure it's working if it is it may not be pulling enough vacuum to activate the pressure switch if it's pulling a good vacuum may be a bad switch. Clear out pressure switch hose. Check switch for proper voltage maybe a bad board
Bigpapi08 is offline   Reply With Quote
Old 02-12-2012, 11:06 AM   #3
Hvac Pro
furnace prob
Originally Posted by jwisn123 View Post
I have an american standard freedom 80 single stage furnace. It is running like normal except it's blowing cold air. What's my 1st step? I opened lower panel and checked for loose wires so far.
Start a new thread as we don`t do 2 at a time or it gets real messy.
Old 02-12-2012, 11:25 AM   #4
HVAC Tech/ Browns Fan
furnace prob
Clean the port by draft motor its going to be the hose from pressure switch to draft motor
Tator1076 is offline   Reply With Quote
Old 02-12-2012, 11:27 AM   #5
furnace prob
Originally Posted by yuri View Post
Check the vent pipes outside for blockage if it is a high efficiency furnace. Post the model # and pics of it so we know which one it is.
If its a Coleman I think it in a house trailer and I hope its not a 90%er
Old 02-12-2012, 12:08 PM   #6
Hvac Pro
furnace prob
Coleman and York are the same now so they have house units. Johnson Controls bought em both.
The Following User Says Thank You to yuri For This Useful Post:
Tator1076 (02-12-2012)
Old 02-12-2012, 12:16 PM   #7
furnace prob
Your right I did hear that
Old 02-12-2012, 12:17 PM   #8
furnace prob
Plus I did see Johnstones had them out on display last time I was there.
Old 02-12-2012, 12:57 PM   #9
Hvac Pro
furnace prob
Coleman sukked but now they are a York product so they are OK.
Old 02-12-2012, 01:25 PM   #10
furnace prob
I had not work on whole lot of york's too. I only worked on the older ones.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
