-   -   Furnace pressure switch line/nipple question (http://www.diychatroom.com/f17/furnace-pressure-switch-line-nipple-question-128254/)
aparman 12-30-2011 11:05 PM
I recently had my inducer/exhaust fan replaced and several times since have found the new inducer fan running but the unit wouldn't fire up. On investigating I find that there are three hoses to the pressure switch. One is marked "-" and is attached to the inducer fan housing. The second marked "+" and connected to the "ignition box" (right name?). The third connects indirectly to the pressure switch by a "T" to the same place on the "ignition box" as the "+" hose, and is then connected to the "gas regulator" (right name?).
The non-flame up only happens occasionally, and can be overcome by sucking on the hose attached to the negative nipple.
Important point: The hose to the pressure switch that connects to the nipple marked "+" has a small plastic plug in it, that fits up into the nipple but cannot enter the nipple because of a small flange on the plug. The hose will fit over this grey plastic plug. This plug has a slot shaped hole in the flange end and a long slit and rectangular opening on the long shaft of the plug itself. Air can move through this plug.
Finally, here is my question: Is this plug a functioning piece of the pressure switch? Or just a leftover piece from when it was packaged?
yuri 12-31-2011 07:29 AM
it is an orifice and MUST be there for the switch to be accurate. check your intake and exhaust pipes for blockage as that usually causes pressure switch tripping problems. post the brand and model # of the furnace for more info.
Marty S. 12-31-2011 07:37 AM
Some use that part and some do not. Perhaps with a brand,model and serial number of the furnace one of the guys will know for sure on yours.
Pressure switches are calibrated to close at a specific point which is printed on the switch. Testing requires use of a manometer.
Tator1076 12-31-2011 04:25 PM
You must have a lennox. Clean out the ports with a small wire. That one on very bottom will plug up fast. That is the common area for the pressure switch not to close
Tator1076 12-31-2011 04:27 PM
p.s its not nipple's its called ports. Get your mind out of the strip clubs:laughing:
