Old 10-10-2009, 02:01 PM   #1
furnace pressure switch
I have a nordyne furnace and the trouble light flashes twice which indicates that the pressure switch is open. Where is the pressure switch located so that I can replace it. and is there a good site that I can order parts from?
Mike T. is offline   Reply With Quote
Old 10-10-2009, 02:06 PM   #2
Master Plumber/Mechanical
Google Nordyne parts
But there may a reason it is open. I would try to diagnose the problem before throwing parts and money at it.
Post Model
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-10-2009, 02:11 PM   #3
biggles's Avatar
you have a small induced draft motor down on the furnace and this is the first item to start on a call for heat.there is a silver pressure disc about 4" in diameter with 1/4 tubes comimg out of it.this switch has to proof that fans air thru the heat-X before the ignition starts and the main burner comes on.....call for heat and tap the disc with a screwdriver handle see if you get ignition.shut down the furnace,pull the tube(off the tap on the duct from the ID motor) might have bug,dirt...in there....spiders like it in there also..lightly blow into the tube from the fan supply tap the pressure switch should click.or it could be black http://bestbuyheatingandaircondition...ode=ps-nordyne
Old 10-10-2009, 02:26 PM   #4
Hvac Pro
Tis the season for the bird in the ventor fan routine.(if it's a mid).
More On This Topic
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will be taking you through the procedures for cutting your work piece on a metal cutting chop saw. The first step is to set your angle plate to whatever angle that you want to cut at... Read More »
Make sure if you have any concerns about using this balance training devise that you get clearance from your doctor. Another thing you can do with vibe disc is to have a spotter, someone that will be with you nearby so that they can provide you support... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Sprint Car Cockpit Anatomy
Sprint Car Cockpit Anatomy by Expert Village
Were going to talk about the cockpit. There's quit a few elements to the cockpit. The number one would be the steering wheel which pops on and off with this lock. This locks the steering wheel when it is up, and unlocks when it is down. It just slips on... Read More »
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Comfortmaker C9MPD100J14C Only goes on when I unplug and Replug pressure switch wire? kevin211mvd HVAC 7 11-15-2008 11:58 PM
pressure switch on pump radams3141 Plumbing 2 04-30-2008 08:14 PM
Carrier Furnace help code 31 fauxjaux HVAC 2 04-10-2008 11:17 PM
Carrier furnace help code 13 mudtruck HVAC 5 04-08-2008 11:47 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
