Furnace Power Wiring Question W/photo - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 04:12 AM   #1
Question
furnace power wiring question w/photo
Swapped out an older beckett unit with a Newer blower motor unit. beckett control module R7184B 1032.
The electrical lines has two sets, one to the upper furnace (to the air blower am pretty sure) and another set of wires, for power I think.. It's the second set am confused by. It has two blacks, a white, and a yellow. All thicker gauge wires. 115VAC. I think the two blacks tie together, and white.. to ac power.. but am stumped what the yellow wire is for.
If it's of help, the first set of wires are smaller gauge: red, black,green,white.
pirateplow is offline   Reply With Quote
Old 12-17-2011, 06:32 AM   #2
An old Tradesmen
Rewards Points: 8,142
Without knowing where those wires are connected at the other end, can't say how they connect.
Tags
wiring furnace power
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Make up ventilation through return on furnace question creamaster HVAC 8 09-27-2009 04:53 PM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
