Old 03-04-2010, 01:15 PM   #1
Furnace plenum
We have been getting a tremendous amount of a very fine light beige colour dust all over the house...Does the plenum accumulate this dust and blow it through the ductwork? How do we stop this powdery dust...we've covered our floor and wall vents with filters and it still doesn't stop this annoying dust? Thanking you in advance for any help in this area!
Brian
Brian Wallace is offline   Reply With Quote
Old 03-04-2010, 01:19 PM   #2
Master General ReEngineer
Bondo's Avatar
Furnace plenum
Ayuh,... There's usually a Filter on the inlet side,...
It's Supposed to stop the dust from even entering the system in the 1st place...
If the system hasn't been protected, Yes, it can load up with all sorts of Crap...
Getting it Cleaned, then keeping that way is probably where you're headed...
Old 03-04-2010, 01:49 PM   #3
Furnace plenum
I change the inlet filter with a $10.00 one every two weeks...why so much dust?
Old 03-04-2010, 01:56 PM   #4
30 year tech
hvac122's Avatar
Furnace plenum
If all those filters didn't stop the dust it is most likely not comming from the duct system. Dust could indicate the house being in a negitive pressure and it could be insulation comming from the attic. The way to stop this is to seal the house up better and mechanicaly bring in outside air as needed.
hvac122 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 03:17 PM
