Old 07-30-2012, 08:45 PM   #1
Furnace on a platform?
Why do HVAC contractors like to install a furnace on a small platform rather than just on the basement floor? Is there a code requirement for this or is it just in case there is water in the basement or something?
lmorsino is offline   Reply With Quote
Old 07-30-2012, 09:29 PM   #2
The only code that i know of that requires furnaces to be elevated are when they are installed in a garage. It is silly but it is to prevent a car from hitting them.
Elavated in a basement may be just for the prevention of water damage. I live in an area with few basements. we are mostly below sea level so I may not be the best one to respond to such a question
turnermech is offline   Reply With Quote
Old 07-30-2012, 09:40 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
It depends on if the basement may or can get water in it. Any time a room is below grade, it can be flooded. Even if you get 2 or 3 feet or even as little as 6 inches in a basement, it can wreck havoc on mechanicals. That is where you need a plan along with a cash fund to cover anything the insurance through your home owner's will not cover.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-31-2012, 07:15 AM   #4
We have a subdivision along our river, and in those homes code required mechanical equipment to be elevated to some degree, and it also required ductwork to be above the flood plain (which is just silly, since the entire dang house was below the flood plain).
In other areas, furnaces are often installed on a plenum (i.e. the metal box that serves as the termination point for the return ducting). Those plenums are generally 12" tall or more.
AFAIK, there is no other requirement for a furnace to be on a platform. We've installed many directly on the concrete basement floor, and the inspectors pass them every time.
Also, different regions have differet established practices, and that may be just one of those practices. For example, in our region you almost never see ductboard in either residential or commercial. However, the RUUD tech rep here reported that another region about 85 miles away uses a LOT of ductboard in residentail apps. Go figure ...
scottmcd9999 is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
