Furnace Pilot Light Will Not Ignite - Carrier 58 GS Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 07:42 PM   #1
Furnace pilot light will not ignite - Carrier 58 GS Furnace?
Carrier 58 gs furnace. With the thermostat off and the blower set to auto the blower fan runs anyway. No matter what setting the blower stays on. I had someone turn it to heat and pump up the temperature while I was downstairs but I didn't hear any clicking or anything. The blower just turns on. The blower door was on so it isn't the door switch. The pilot won't ignite. It worked a week ago to get ready for the winter season but has now just stopped working. Any pointers is much appreciated.
Wiring diagram says "heating fan relay contact is normally closed until 110v AC is applied to furnace". I'm not sure if that has anything to do with it but the heating fan really is closed at the moment. Is that why the fan is always on?
rasilun is offline   Reply With Quote
Old 10-29-2011, 08:02 PM   #2
Rewards Points: 508
Tell what point you are at:
1. Combustion fan/induced draft fan comes on
2. Pressure hose jumps, air pressure switch closes/clicks
3. Ignitor glows
4. Gas valve opens, burners light
5. Blower motor starts
diyorpay is offline   Reply With Quote
Old 10-29-2011, 08:44 PM   #3
I think I have it narrowed down to the limit switch per the diagram. Getting ready to go check it.
Old 10-29-2011, 09:38 PM   #4
Ok I have determined that the problem is that the VSSS Vent Safety Shut off Switch has been tripped most likely because the filter was severely clogged. I have jumped the limit control switch and there was no difference but once I jumped the VSSS everything is running fine. Next question, the manual says to reset the VSSS but it does not anywhere in here tell me how to reset it.
Pilot lite on Carrier Furnace goes out nmac HVAC 8 10-08-2012 06:32 AM
pilot light does not stay lit in wall furnace daoudi Plumbing 0 06-20-2011 12:49 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 06:41 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
