Old 11-20-2012, 07:20 PM   #1
Furnace over OSB or concrete?
Hi. Hoping for your good advice.
Doing a basement renovation in a late 70's house in northern Canada. I've built a subfloor of 5/8 T&G OSB over 1" rigid styrofoam everywhere but where the furnace and hot water heater sit.
Of course layout plans changed. Now I'm being asked by my better half to move the furnace and hot water heater to a place that makes a lot of sense, and would work out well, but already has the subfloor tapconned down. And the concrete floor underneath is very out of level.
My question: Can I put them on top of the subfloor, or should I pull it out and level the concrete floor, then install the furnace and hot water heater on the concrete?
Really appreciate your thoughts. Thanks.
northernlite is offline   Reply With Quote
Old 11-20-2012, 07:42 PM   #2
no problems on a sub floor here....depends on your local codes.....
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
northernlite (11-20-2012)
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 11 12-16-2012 07:18 AM
Concrete Furnace Slab in 1920s Off-Grade home meowhouse Concrete, Stone & Masonry 0 09-04-2012 11:50 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
