Old 11-03-2009, 10:33 PM   #1
Exclamation Furnace Output
I am wondering about the temperature of the heat coming from my floor registers. It feels lukewarm. Outdoor temperature was about 56 but I guess that shouldn't matter.
Putting a thermometer to the air coming out of register gives a reading of 107 degrees (after about 30 minutes of running) and that is as high as it will go. Does anyone know if this is normal? My furnace is proper size for sq footage of house, if that matters.
I had thought the heat exchanger heated the air and that once it starts blowing, the temperature doesnt slowly work its way up, over a period of 30 minutes. Is that incorrect? As I say it takes mine 30 minutes to get to 107 degrees. My previous furnace seemed to put out hot air within a few minutes.
Replies would be appreciated.
MinervaSue is offline   Reply With Quote
Old 11-03-2009, 11:17 PM   #2
Houston204's Avatar
Is this a gas furnace?
What is the air temperature entering the furnace?
Houston204 is offline   Reply With Quote
Old 11-04-2009, 07:17 AM   #3
An old Tradesmen
No such thing as sized right for the square footage.
As above. is it a heat pump or gas furnace. What is the air temp entering the return. Do you have a basement that your ducts are in, or is your floor a slab.
Old 11-05-2009, 08:16 PM   #4
I have Downflow multiposition gas furnace in utility room. House has insulated crawl space. The morning air going into furnace was 59 degrees . Air coming out of closest vent (15-20 feet from furnace) was lukewarm for about 15 minutes then got to 100 degrees and then to 105 after 5 more minutes , then slowly to 107 and that seems to be the limit. Mayabe 107 is all I can get from this furnace or maybe the heat exchanger (? ) releases the air to the blower while it is still lukewarm. (Blower cames on 1 minute after themostat kicks on. ) Outdoor temps have been 40 at night and 60-70 daytime. I have never had a furnace that didn't have nice warm heat at the vent within just a few minutes. This one gradually works its way up and one day it took 19 minutes for it to go from 104 degrees up to its limit of 107. Also the transformer hums. The technician said transformers are supposed to hum, but he replaced it and the new one hums too.
Old 11-05-2009, 08:34 PM   #5
An old Tradesmen
Does the utility room have its access door on the outside of the building.
Or does it have combustion air intakes that run outside. If yes for either. If the air filter access is in the same room. Can it be pulling in cold outdoor air in the filter access.
Old 11-05-2009, 08:35 PM   #6
Houston204's Avatar
Your furnace should display the rated temperature rise in the burner section near the model and serial number. A 35 to 60 degree rise in temperature across the furnace is a common rating.
Old 11-05-2009, 09:09 PM   #7
Access door from kitchen, no combustion air intakes from outside. Brochure indicates heat rise 35-65 for this furnace.
Old 11-05-2009, 09:45 PM   #8
i was just about to ask this same question. my furnace feels the same way. i just installed it, and i hired a guy to build the plenum and the main trunk. when i test ran it the air felt luke warm. it could be because my house was only 45-50 deg. when i ran it. but i am thinking the trunk this guy installed is only 8X10", maybe this has something to do with it?
drewhart is offline   Reply With Quote
Old 11-05-2009, 10:01 PM   #9
My previous furnace worked fine in this house. It was an oversized (so I was told by a friend)---120,000 btu for a ranch under 1200 sq ft. This one is 75000 and seems fine for this house except for the humming transformer and the slowness of heat to the vents.
Old 11-05-2009, 10:33 PM   #10
Yoyizit's Avatar
Does the flame look the same while the air gets slowly warm?
Does your lukewarm feeling correspond to your thermometer readings? Thermometers have a thermal time constant, which may run to a few minutes depending on their thermal mass.
When the thermometer gets to 107 put it in a room at 72. The time it takes to go from 107 down to 85 is the time constant.
Yoyizit is online now   Reply With Quote
Old 11-05-2009, 10:34 PM   #11
Houston204's Avatar
Sounds like you have at least a 41 to 46 degree rise. This is within range.
You can't expect it to heat as much as your oversized furnace.
Is your ducting well insulated?
Old 11-05-2009, 10:47 PM   #12
Yoyizit's Avatar
If your furnace is right-sized it could take a long time to reach the t'stat setpoint. And your furnace would run almost continuously.
What kind of cycle times did your larger furnace have? I think it reached 107 in 6 minutes, which I think is the time constant for your house and the air that's in it.
Old 11-05-2009, 11:30 PM   #13
I cant see the flames in this furnace. They are behind a closed panel. The ducts are not insulated. The house has a masonry covering.
As to the 107 degrees, when it finally gets to that point at the vent, it feels warm. But it doesn't seem like the exchanger wants to send 107 degree air to the vent. It is more like the exchanger wants to "think about it" for 15-20 minutes while it sends cooler air .
I don't really expect this furnace to heat the house as quickly as the bigger one did, but I assumed the properly heated air would come out of the exchanger to the vents within 2 to 3 mintues as in every house I have lived in, seemingly regardless of size of home or size of the furnaces.
My bigger concern now is what happens when really cold temperatures hit my locality if the warm air is this slow getting into vents now. The velocity of the air seems okay, but not the temperature, at least not until it gets to 107.
Old 11-05-2009, 11:44 PM   #14
Yoyizit's Avatar
1
2
3
1 You could check that your gas meter runs as fast at turn-on as it does minutes later.
2 My houses too, but furnaces may routinely be oversized.
3 I guess your furnace should be sized for the 97.5 percentile temperature.
Old 11-05-2009, 11:45 PM   #15
Extreme DIY Homeowner
Scuba_Dave's Avatar
60-70 in the day & you have the heat on ?
We've had frost here, only up to 50 during the day & haven't turned the heat on yet
Supposed to be close to 60 thru Tues - so no heat until after then at least
The new furnace will lower your heating bills
On colder days it will run longer & more often
In a "perfect" system the air would be coming out constantly at about the Temp you want the house to be
No wasted fuel "overheating" the house
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
More On This Topic
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
More Ways to Glaze Pottery
More Ways to Glaze Pottery by Expert Village
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. Now our firing is completed, after 1100 degree Cecilius temperature we keep the furnace 1 day for cooling. Now I'm opening the furnace see this is the door and our cups... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Hi, I'm Doug. I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now that Andy has shot the primer, the base coat, the candy coat and two coats of clear, we're ready to... Read More »
Rheem 90 Plus modulating furnace - low output lifeisfun HVAC 0 01-23-2009 09:42 PM
Furnace air filtration advice stephen_smith HVAC 5 01-12-2009 09:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 5 11-07-2008 06:52 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
