Furnace Only Works With Panel Off - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2015, 05:20 PM   #1
Rewards Points: 4
My 5-year old high-efficiency ICP furnace won't stay lit with the burner panel on.
With the panel on, I look through the little window, and the last burner (where the flame sensor is) flickers and then goes out after 30-60 seconds. The fan keeps going and it cycles through that way a few times. The LED code suggests "failure to ignite" (which I can see is not the case) or "flame sense lost", then eventually "soft lockout."
When I take the burner compartment panel off, everything works fine, but I'd rather not leave it like that, with an exposed flame.
Both the air filter and the flame sensor have been replaced recently. The furnace was doing this same thing a month ago, so I replaced those 2 items. I verified that all of the exhaust pipes that I can reach are clear. (We did recently have a large snow, but the last 2 days have been warm enough that a whole lot of that has melted, and the problem didn't start until this morning, 3 days after the big snow.) What ultimately seemed to work last month was opening more ducts/vents wider than I had them previously. It worked fine for a month, then started misbehaving again.
Please help! Thanks
cronos6939 is offline   Reply With Quote
Old 02-24-2015, 05:36 PM   #2
Rewards Points: 289
Yes, don't run it with the burner box cover off. Do all the burners go off at once or just the last burner?
Bitters is online now   Reply With Quote
Old 02-24-2015, 05:48 PM   #3
Rewards Points: 4
The 4th/last burner sputters and goes out. Since thats where a flame sensor is, the others go out a moment later.
Old 02-24-2015, 06:03 PM   #4
Rewards Points: 568
Clean out burners/orifices and try again. That flickering burner may not be getting enough gas.
Also when you say the fan keeps running do you mean the ID fan or the forced air blower?
techpappy is offline   Reply With Quote
Old 02-24-2015, 06:04 PM   #5
Rewards Points: 289
OK, sounds like the gas pressure is low. Or the manifold is dirty.
Old 02-24-2015, 06:26 PM   #6
Hvac Pro
Rewards Points: 2,008
The intake pipe outside may have sucked in snow or the exhaust gas recirculated back into it. Taking the cover off gives it more combustion air. Take a shop vac that can blow air and stick it on the intake pipe outside and turn it on and see if air blows into the furnace. You may have to use a heat gun or hair dryer and blow heat in to defrost it. A leaf blower also works. Same thing can happen to the exhaust but it is less likely as it is warm and pushing out not sucking in like the intake.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (02-24-2015)
Tags
cover , flame , flame sensor , furnace
Furnace only works when raining mikethe ductman HVAC 9 11-24-2014 08:45 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
Furnace only works with door off CWinGA HVAC 3 12-05-2009 05:36 PM
