Furnace Only Works With Door Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 12:49 PM   #1
Question
Furnace only works with door off
I have a Governaire standard efficiency furnace. The furnace has been cycling every three minutes or so. I noticed that the furnace runs fine with the burner access door off. If i slowly start to put it back on, I can feel a lot of suction and I can see the flame blow out. It seems like the sensors and switches work okay and the furnace is shutting down (correctly) because the flame sensor cannot detect a flame.
Any ideas about what the problem is and how to fix it? Any help is greatly appreciated.
BERVIN 306 - I think you are on the right track. There is no intake pipe. The furnace is in a crawlspace and there is plenty of ventilation, but I think there may be a restriction in the flue causing a pressure drop. I think the inducer fan can produce enough static pressure to overcome the restriction, but not with extra restriction of the access door.
CWinGA is offline   Reply With Quote
Old 12-05-2009, 01:28 PM   #2
Without looking at it I can't be positive, but anyway you look at it you probably need a professional. If the flame is being Blown out by the blower coming on you might have a cracked heat exchange. This is very dangerous. Meaning turn it off until it's repaired. Another possibility could be a partially clogged flue. First thing I would do is check your filter. Next I would call a Pro.
mercdady is offline   Reply With Quote
Old 12-05-2009, 03:23 PM   #3
Sounds like a crack has turned into a massive hole. Shut it off and call a pro.
Old 12-05-2009, 04:36 PM   #4
Your fresh air intake pipe is most likly clogged. You need air to make fire. That's why it works with the door off. Check your intake pipe there should be a screen right before it goes into the burner box, see if you see any leaves. Also check the outside make sure it is clear. if all else fails blow out the pipe.
bervin306 is offline   Reply With Quote
Tags
cycling , draft , furnace
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
