Old 02-20-2013, 05:27 PM   #1
furnace only turns on when 75 degrees or higher
is this a thermostat problem? or how should i go about fixing this, its boiling hot in here!
PiPiFirecracker is offline   Reply With Quote
Old 02-20-2013, 05:37 PM   #2
Did it every work correctly?
Did you install the thermostat yourself?
Did you buy a conbination heating and cooling thermostat and hook up the furnace control leads to the cooling terminals (turns on when the termperature goes up)?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 02-20-2013, 06:11 PM   #3
yes, no, and there is the cooling option, but no ac here, and i did not hook it up
Old 02-20-2013, 06:55 PM   #4
is there some way i can check to see? or a way to test it? it is set to heat right now...
Old 02-20-2013, 07:00 PM   #5
sorry i don't know if it ever worked correctly, were just renting and the landlord isn't really smartthere fore thinks it works even when i explain its broken.... but hes nice so i don't wanna push him to repair it, i'd rather deal with it myself... it would be faster I'm sure
Old 02-20-2013, 10:57 PM   #6
Roofmaster
T stat is hooked up backward.
" A lot of men build things, and a lot of things fall down "
Old 02-21-2013, 06:21 AM   #7
An old Tradesmen
Post brand and model number of thermostat.
Old 02-23-2013, 07:19 AM   #8
So if you burn the place down by doing work, as a renter, you want to be responsible?
It's his responsibility as a land lord! Have him call a qualified tech and make repairs that's why you pay rent?
Jmo
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Moving furnace 90 degrees jimmyfloyd HVAC 3 02-20-2013 06:31 PM
Furnace Blower turns on before ignition. furnacelady HVAC 1 02-06-2013 09:27 AM
Furnace intermittently turns off. Lennox G23Q23-75-2 mccow001 Appliances 0 03-29-2012 10:16 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Heil NG Furnace - Combustion blower never turns off PHRoberts HVAC 4 06-11-2010 05:37 AM
