-   -   furnace only turns on when 75 degrees or higher (http://www.diychatroom.com/f17/furnace-only-turns-when-75-degrees-higher-172501/)
PiPiFirecracker 02-20-2013 04:27 PM
is this a thermostat problem? or how should i go about fixing this, its boiling hot in here!:eek:
AllanJ 02-20-2013 04:37 PM
Did it every work correctly?
Did you install the thermostat yourself?
Did you buy a conbination heating and cooling thermostat and hook up the furnace control leads to the cooling terminals (turns on when the termperature goes up)?
PiPiFirecracker 02-20-2013 05:11 PM
yes, no, and there is the cooling option, but no ac here, and i did not hook it up
PiPiFirecracker 02-20-2013 05:55 PM
is there some way i can check to see? or a way to test it? it is set to heat right now...
PiPiFirecracker 02-20-2013 06:00 PM
sorry i don't know if it ever worked correctly, were just renting and the landlord isn't really smartthere fore thinks it works even when i explain its broken.... but hes nice so i don't wanna push him to repair it, i'd rather deal with it myself... it would be faster I'm sure
jagans 02-20-2013 09:57 PM
T stat is hooked up backward. :laughing:
beenthere 02-21-2013 05:21 AM
Post brand and model number of thermostat.
digitalplumber 02-23-2013 06:19 AM
So if you burn the place down by doing work, as a renter, you want to be responsible?
It's his responsibility as a land lord! Have him call a qualified tech and make repairs that's why you pay rent?
Jmo
