Furnace Only Runs Sometimes - HVAC - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 05:05 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Furnace only runs sometimes
Furnace will come on and run fine sometimes. But does not always come on when it should. If you push the thermostat up to try and force it to come on it won't. If you set it on 70, sometimes when the temp drops it will come on, sometimes it won't. Bad thermostat? It works good when it comes on.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-03-2011, 05:18 PM   #2
biggles's Avatar
remove the stat from the subbase see that R and W thats what the stat closes to run the heat..remove the W wire and touch it to the R the furnace should run if it short cycles or not at all it is the furnace....aas long as R/W it touching the furnace should run
The Following User Says Thank You to biggles For This Useful Post:
rusty baker (10-03-2011)
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
What runs before furnace starts rosco HVAC 12 03-20-2010 11:57 AM
furnace runs for short periods dodge1972 HVAC 3 01-08-2010 10:54 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
