Furnace Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 06:44 PM   #1
Furnace not working
I have two electric heat pump furnaces. Today was the day I decided to switch from A/C to heat. I turned the Honeywell thermostat to heat, and the thermostat said "Heat on" but the furnace/fan did not come on at all. I did the same for my second zone upstairs, and the same problem occurred. When I switch back to A/C, that function no longer worked either. Now the heat pump is not coming on at all. I checked all the breakers, and they looked fine. Where do you think the problem is?
CooperRex is offline   Reply With Quote
Old 09-18-2011, 04:58 AM   #2
An old Tradesmen
Rewards Points: 6,914
Might have blown the fuse for the transformers low voltage side. Need to check for a short in the low voltage side of the control circuit.
Old 09-18-2011, 09:19 AM   #3
Thanks for your reply.
Where is the control circuit? Is this within the furnace itself or are you referring to something in the thermostat or the main electrical panel?
Thanks!
Old 09-18-2011, 11:12 AM   #4
An old Tradesmen
All of the low voltage components. That includes the thermostat, its wires, the wires to the A/c,etc.
Old 09-18-2011, 11:24 AM   #5
There is a time dealy when switching from cooling to heating.
Master of Cold is offline   Reply With Quote
Old 09-18-2011, 01:41 PM   #6
Thanks for your the replies.
I'm going to call the HVAC company tomorrow.
Assuming this is some kind of transformer short in the low voltage wires, what kind of repair is necessary? Do they have to put new wires through the walls? How much do you this will cost me?
Also, this is a brand new Honeywell thermostat that was installed this summer by an electrician. He replaced our old mercury thermostats. Should I assume that this problem means that he hooked up the wires incorrectly? There were no issues with A/C this summer with the new thermostat.
Thanks.
Old 09-18-2011, 04:03 PM   #7
An old Tradesmen
Can't tell from here where the exact problem is. nor can we say it was the electrician's doing or not.
Please help, furnace not working!!!!!! Sfeyelectric HVAC 7 03-31-2011 06:20 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
RUUD furnace not working blower runs ddeatrick99@hotmail.com HVAC 2 01-16-2008 09:55 PM
Furnace not working right TheBillman HVAC 2 11-20-2005 05:31 PM
