Furnace Not Staying Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 05:16 PM   #1
furnace not staying lit
Goodman Model # gmt070-3a
Serial # 0303602933 furnace tries to lite 3 times then shuts off. Tried cleaning the flame sensor rod.
wickwicky is offline   Reply With Quote
Old 10-08-2011, 06:55 PM   #2
Does the ignitor come on? Do you have gas going to the unit?
Master of Cold is offline   Reply With Quote
Old 10-08-2011, 06:59 PM   #3
Rewards Points: 1,300
I am not real familiar with this brand/model of furnace. Do the burners get lit by a hot plate igniter or spark igniter or does a pilot get lit then the burners? Some models of 80% furnaces have an intermediate pilot the flame sensor needs to see before the burners light. If this is the case, make sure the pilot is burning enough to keep the flame in the sensor when the burners come on. If it does not have a pilot is the sensor in the flame when the burners come on? Some background may also be helpfull. Has there been any work done on or near the furnace electricaly?
danpik is offline   Reply With Quote
Old 10-08-2011, 07:32 PM   #4
It was installed in 03 and that's about all I know of its history. It's got a hot plate that gets red to light the burner. There is a rod that is separate that is the flame sensor.
Old 10-08-2011, 07:34 PM   #5
The flames do come on but only for a few seconds then shut off. It does that 3 times then stops lighting and just blows cool air.
Old 10-08-2011, 07:37 PM   #6
An old Tradesmen
Rewards Points: 7,768
Probably a dirty flame sensor.
Old 10-08-2011, 08:51 PM   #7
Take the burners out and clean them too. The flame sensor is only 1/3rd of the flame proving sequence. Clean burner faces for a good return to ground and the circuit board are the others 2/3rds of the mix.
Old 10-08-2011, 11:22 PM   #8
Do you mean the pipe that shoots out the gas originally?
Old 10-08-2011, 11:39 PM   #9
JJboy's Avatar
Service manual
http://www.google.com/url?sa=t&sourc...YFUzSQ&cad=rja
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-15-2011, 03:34 PM   #10
Thanks to all who posted. Not sure exactly what it was but after trying everything n testing I now have heat. Thank you.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
