Furnace Not Putting Out Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2005, 10:53 AM   #1
furnace not putting out heat
I have an old Lennox electric furnace (model# ES2-681-2) that is only putting out slightly warm air, it does'nt put out the hotter air. Any suggestions as to what may be the problem or what I should possibly check. Any help would be appreciated.
diff is offline   Reply With Quote
Old 01-07-2006, 12:20 PM   #2
weinstall.ca
Post
Most likely the sequenchers or elements some work some dont.
easy fix if you have a meter check out the ohms on each individual
element if it goes to infinity replace
alln Clarkson Comfort Zone Heating
Mississauga
weinstall.ca
allan is offline   Reply With Quote
Furnace - fan comes on, but no heat albionwiggina HVAC 5 02-12-2007 03:37 PM
Furnace blew up, need to replace heat and air with single unit. d_Random HVAC 2 02-06-2007 05:18 PM
no heat when turn furnace on atl HVAC 1 10-24-2006 01:38 PM
