Furnace Not Putting Out Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 06:05 PM   #1
furnace not putting out heat
I have a gas furnace that is not putting out heat. It does not have a pilot light. I had a technician in last night and he tested the furnace and felt that the problem was the thermostat. He reset the thermostat and we changed the batteries and heat was coming out before he left and did for about 24 hours. Now I am back to no heat (just air).
I tried turning off furnace and turning back on. I also reset the thermostat (Noma programmable) and no luck. It recognizes the temperature and shows that it has turned the heat on but the air vents only have air blowing. No heat.
What can I do?
nilmerf is offline   Reply With Quote
Old 12-03-2011, 06:37 PM   #2
My furnace doesn't heat but the blower works isn't much to go on. How about checking the sequence of operation and telling us which step is missing.
Inducer comes on?
Ignition system sparks or glows red hot?
Gas valve energized?
Gas present?
Flames start for any length of time?
Old 12-03-2011, 06:46 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 180
Brand name, model and serial # would help also.
Old 12-03-2011, 07:59 PM   #4
biggles's Avatar
doesn't have a pilot light that is OUT or a spark ignition... not sparking...did the tech show you how to light the standing pilot?
Olsen Furnace - No Heat CaptnD HVAC 1 10-26-2009 10:26 PM
Furnace room is warm, wasting heat Richo HVAC 13 02-18-2009 12:57 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
furnace not putting out heat diff HVAC 1 01-07-2006 11:20 AM
