Furnace Is Not Kicking On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2008, 04:13 PM   #1
Furnace is not kicking on
We have a carrier furnace 8 years old. I have the thermosstat set to 70 degrees around the clock, as it gets cold in here. This morning I woke up, the house was freezing and the temperature read 63 degrees on our thermosstat. I manually put it to 72 degrees, the furnace went right on.
The LED light on our furnace is solid red, so therefore it is not indicating there are any problems. Last year, we had replaced the ignitor. The filter was just changed last week, so I'm not sure what the problem could be.
Any ideas?
mterracciano is offline   Reply With Quote
Old 12-04-2008, 05:02 PM   #2
Rewards Points: 109
Sounds like the thermostat was stuck. Don't panic yet. If it was the furnace it wouldn't fire just from raising the set point 2*. If it continues to do this you may have a bad thermostat.
Daltex is offline   Reply With Quote
Old 12-04-2008, 05:17 PM   #3
Well I reprogrammed all the temperatures to 72 degrees on my thermostat and the furnace went on by itself, so hopefully you were right and it was just a stuck thermostat. Thanks!
Old 12-04-2008, 07:08 PM   #4
If you have a T-87 honeywell no-programmable t-stat your heat anticipator may not be set correctly, if you have a programmable thermostat, (such as a honeywell chronotherm III) the t-stat may be running a program you didn't indicate for it to run. In which case, especially with that Chrono III replace the stat.
J_theo is offline   Reply With Quote
Old 12-04-2008, 07:42 PM   #5
Hellenas?
hvaclover is offline   Reply With Quote
Old 12-04-2008, 10:08 PM   #6
The control board may need to be replaced.
NYCtinman is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 09:35 AM
