Furnace Not Igniting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 10:18 PM   #1
furnace not igniting
my Armstrong furnace is not receiving gas through the valve
Sudhir is offline   Reply With Quote
Old 09-26-2011, 11:05 PM   #2
JJboy's Avatar
did you pay gas bill? if you're not receiving gas.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-27-2011, 12:10 PM   #3
REP
If you are getting 24v to the valve and its not opening,you have a bad gas valve.
If you are not getting 24v to valve (my guess) then you have a control problem.
REP is offline   Reply With Quote
Old 09-27-2011, 02:15 PM   #4
Sudhir, we need more info in order to properly diagnosis. Turn heat on and check the furnace. Did you see the ignitor glow? What is the brand and age of unit?
The more info we have the better. You dont want to just replace parts after parts.
Mr.HVAC is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 06:41 AM
furnace keeps igniting forever !! tommyle HVAC 7 10-19-2009 10:38 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
