Furnace Noise ,gas Light Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 04:36 AM   #1
Furnace noise ,gas light shut off
Basically my furnacewas running and when it shut off, it made a loud bang noise and the pilot light went out and we could smell burning and gas ...... ? What could it be? And what should I do ??
Davana211 is offline   Reply With Quote
Old 12-11-2011, 05:51 AM   #2
An old Tradesmen
Rewards Points: 6,480
Could be a cracked heat exchanger, bad gas valve, or other serious problem. may want a tech to check it. unless you are comfortable checking for a leaking gas valve, and have the equipment to check it.
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 07:51 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 08:49 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 03:31 PM
Oil furnace won't shut off tef HVAC 3 11-13-2007 09:43 PM
