Old 11-28-2009, 01:15 PM   #1
furnace noise
Our garage was converted into a family room. The furnace is in it and has had a closet built around it. We would like to cut down the noise level and were looking to insulate the walls but the doors are accordion slatted door. I was told that slatted doors were used to vent off heat. Could we put in insulated solid doors and vent into the crawl space under the house. The furnace is against an inside wall. If this is possible, how large of a vent will be needed?
debd is offline   Reply With Quote
Old 11-28-2009, 01:42 PM   #2
Hvac Pro
furnace noise
You need to have adequate clearance to combustible wood etc from the furnace as well as air for combustion and ventilation of the furnace and safety, insurance reasons , codes etc. I would leave it alone or get a Pro to assess it and look up the specs in the code book.
Old 11-28-2009, 03:38 PM   #3
It was a dark and stormy
Yoyizit's Avatar
furnace noise
Reducing blower speed by 13% can cut the noise level in half but this could make problems with your heat exchanger.
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 7 05-07-2010 11:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 03:31 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 05:05 PM
