Furnace Needs To Push More Air - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 11:22 AM   #1
Furnace needs to push more air
I have a Trane XE90 working in conjunction with an outdoor wood boiler. Due to poor ducting when the house was built, air flow from vents is terrible. I can barely feel air coming from most spots of the house and it takes forever for the place to warm up.
My 1/3hp blower motor just blew out and I need to replace it. Would it be beneficial to upgrade to 1/2hp with more RPM or is that not advised? Any other suggestions?
Thanks,
Mark
phatsupratt is offline   Reply With Quote
Old 10-18-2011, 11:54 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
isn't that motor a multi speed motor? that doesn't mean it changes speeds on it's own during a call for heat, it means that it has different speed taps so manually you can adjust to low or medium low, medium high and high on that motor. high is usually used in cooling and low on heating so if it is a multi speed than you can move the speed up from low to medium low and get more air velocity in heating mode, if it is on low speed and has speed taps.
Also I'd check all of the duct work for leaks, exposed liner/broken insulation and possible kinks in the ducts.
Doc Holliday is offline   Reply With Quote
Old 10-18-2011, 12:49 PM   #3
Thanks for the reply, Doc. Yes, it is multi speed and I have it on the highest setting (black wire).
Old 10-18-2011, 01:07 PM   #4
Instead of adding to the frankenstien that is your system byway of putting in a different motor, I'd fix the real problem, duct work.
It'll never be right until then, no matter what else you do, me thinks.
Old 10-18-2011, 01:12 PM   #5
New r6 or r8 insulated duct work and better insulation for the home.
Old 10-18-2011, 01:41 PM   #6
biggles's Avatar
either the ducts are leaking at the joints or it is too diffused maybe size down he worst
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
