Old 12-24-2006, 08:41 PM   #1
Furnace mounted on its side....
I have a Ruud Silhouette gas furnace with AC coil attached at the top.
I have seen electric furnaces installed horizontally, on their sides.
They were installed in attics and crawlapaces.
My question is, can I install a gas furnace this way?
Due to remodeling and space constraints, The most convenient
place for the furnace is in the attic if this is possible.
I would build a properly sized chase for adequate cold-air return
from the floor of this one-story house.
The heat ducts are in the cieling already.
Thanks for any advice...
Bob
jbob is offline   Reply With Quote
Old 12-25-2006, 01:27 AM   #2
I dont know if the current furnace that you have is sutable for such a aplication. But you purchace a top of the line Lennox that is designed for just such an application.
acefurnacefixer is offline   Reply With Quote
Old 12-25-2006, 06:19 PM   #3
most manufactures of furnaces make furnaces for horizantol installs
trollmastergeneral is offline   Reply With Quote
Old 12-26-2006, 06:15 PM   #4
I think thats common knowllage
Old 12-26-2006, 09:37 PM   #5
remodeling pro
[quote=acefurnacefixer;27853]I think thats common knowllage[/quote
Hopefully to those in the ac/heat trades, but not to a homeowner.
And even that "hopefully" is not always true. I had an ac contractor install a gas furnace horizontally in an attic on a job several years ago. When I went into the attic , the access door was facing up on the unit, thus putting all of the wiring directly above the burner. When I questioned him about this, he became angry and loudly stressed to me that he had been in the business for more than 15 years and this was a furnace rated for either vertical or horizontal applications. I found the installation manuel in the trash pile, and he was right, problem was it could be laid horizontally on either it's right or left side, not on it's back like he had it. I called the distributor and he verified that my interpretation was correct, and finally the installer changed the orientation with much grumbling about how much this was costing him because he was going to have to remake both the supply and return air plenums.
troubleseeker is offline   Reply With Quote
Old 12-26-2006, 10:36 PM   #6
Thoroughbred Mopar Man
Hi jbob
All major manufacturers produce a horizontal furnace in some capacity. The one thing to be careful about is a 90 plus condensing furnace. They can be installed if horizontally equipped. You just need to take care in disposal of the condensate, follow the manufacturers approved method, I don't care how much experinece someone has as this. The manufacturer knows what this equipment was designed to do.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
