Furnace Motor Vibration - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 08:59 PM   #1
Furnace motor vibration
I just replaced my blower motor and I noticed when I look at the motor operate it has a slight vibration. The blower seems to spin true and like I said the vibration is a slight back and forth wooble. You wouldn't notice it (ie the furnace doesn't make any special noises) unless you looked at the motor when the blower was turning. My question is this vibration normal or should I be concerned?
elou795 is offline   Reply With Quote
Old 09-25-2010, 06:16 AM   #2
An old Tradesmen
Rewards Points: 7,794
Its probably the blower wheel balance is slightly off.
Spinning a blower wheel by hand, doesn't match to it spinning at 900 or more RPM.
Old 09-25-2010, 06:47 PM   #3
Will the blower being slightly off damage the motor?
Old 09-25-2010, 06:52 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes, eventually.
Old 11-19-2010, 08:45 PM   #5
new guy with same problem (furnace vibration)
Hello everyone,
How can I stop the blower assembly vibration? I think mine is worst than the first gentleman.
When I first noticed the vibration, I went out and bought a new after-market motor, motor bracket, and blower wheel.
I installed everything brand new, but I still get the vibration, same or worst than before.
The wheel came pre-balanced (seems to me), since it has some weights attached. The motor bracket seems flimsy to me, so could be part of the problem. Attaching the motor to the squirrel cage is only three bolts. I am not really sure what to balance.
Any help would be appreciated. (By the way, the Furnace is a goodman GMS81155CNA Upflow Single Stage 80% AFUE 115,000 KBTUH Maximum CFM @ .5 ESP 2000 21 wide, Natural Gas, Initial Revision)
By the way, I am glad that I replaced all the parts, the blower wheel was extremely dirty and the motor was worse (the prior owner did not use a filter for several months).
s0ftimage is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
