Furnace Motor Speed Change - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 12:14 PM   #1
Furnace motor speed change
I have a wood/electric furnace combination with a 3 speed motor. When I use the wood furnace, I would like to have the motor run continuosly on low speed. I need to change the wiring that goes from the manual switch to the motor. I know I only have to switch the wires from medium speed to low speed. How do I do this?
Bob Ticknor is offline   Reply With Quote
Old 12-07-2011, 05:39 PM   #2
biggles's Avatar
speeds are olor coded off the motor tag just flip the speeds might consider a 2-3 ploe speed switch so you don't have to do the wires
Old 12-08-2011, 04:32 PM   #3
If not on the motor tag, try on back of blower door for schematic. Wire harness often in a box with a cover. You'll probably see some of the wires with the colors in the schematic 'going nowhere' with just a wire cap. They aren't being used. The 'real' one, under a wire cap but connected to the motor is the one currently controlling speed. With power off, switch wires.
But as biggles suggests, if you're going to change speeds often, consider a switch box control.
diyorpay is offline   Reply With Quote
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
ducane gas furnace fan speed change homebound479 HVAC 3 09-30-2010 05:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 07:53 AM
