Furnace Motor Runs Slow - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 11:50 AM   #1
I have a 5 year old Armstrong Hiboy direct drive oil furnace that also provides A/C from an outdoor Trane unit. A few nights ago with the A/C on, there was barely any air coming from the registers. Opening the furnace access panel, the blower was running but very slow. I shut the unit off and then turned it back on and the blower did not turn but made a humming sound. I turned off the unit again, gave the blower a spin, turned it on and it was now running at a normal high speed. After running about an hour, I cycled the power again and the blower was back to running slow.
I havenít pulled out a meter yet to test, but reviewing the wiring (black, blue and white to the motor) and schematic, there is a relay switch (with low voltage violet wires) and a fan limit switch. Just wondering if these components could be the issue or if itís the motor itself? Bad starter cap or winding?
Thanks!
Cjshaw is offline   Reply With Quote
Old 08-23-2012, 12:42 PM   #2
Probably a capacitor for now. Keep runnig it like that and you'll need a motor too.
Old 08-27-2012, 12:04 PM   #3
Bingo! Replaced the 7.5 mfd 370v cap on the blower motor and all good! $6 at Graingers.
Thanks!
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Furnace blower only runs VERY slow... tippet HVAC 12 12-04-2010 04:50 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
