-   -   Furnace Motor Runs Slow (http://www.diychatroom.com/f17/furnace-motor-runs-slow-154583/)
Cjshaw 08-23-2012 11:50 AM
I have a 5 year old Armstrong Hiboy direct drive oil furnace that also provides A/C from an outdoor Trane unit. A few nights ago with the A/C on, there was barely any air coming from the registers. Opening the furnace access panel, the blower was running but very slow. I shut the unit off and then turned it back on and the blower did not turn but made a humming sound. I turned off the unit again, gave the blower a spin, turned it on and it was now running at a normal high speed. After running about an hour, I cycled the power again and the blower was back to running slow.
I havenít pulled out a meter yet to test, but reviewing the wiring (black, blue and white to the motor) and schematic, there is a relay switch (with low voltage violet wires) and a fan limit switch. Just wondering if these components could be the issue or if itís the motor itself? Bad starter cap or winding?
Thanks!
Marty S. 08-23-2012 12:42 PM
Probably a capacitor for now. Keep runnig it like that and you'll need a motor too.
Cjshaw 08-27-2012 12:04 PM
Bingo! Replaced the 7.5 mfd 370v cap on the blower motor and all good! $6 at Graingers.
Thanks!
