Furnace Motor Is Running But No Air Out - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 12:59 PM   #1
Furnace motor is running but no air out
I have a very old (~1989) gas furnace at home. When it works, first, I can hear motor starts running but no air out for about 1 min. After 1 min, the air (eventually hot) comes out.
This morning, the motor is still running (I can still hear it), but it never blows. Can you please advice what could be the problem? Do you think it's serious that I should just replace the furnace? I will call a HVAC pros next week but it's cold so if I can fix it myself that would be great.
Thanks.
thone is offline   Reply With Quote
Old 01-15-2012, 01:34 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
post the make and model of the furnace and some pics of the motor. does it have a belt?
Old 01-15-2012, 01:37 PM   #3
Rewards Points: 12,794
Loose belt, broken belt, loose screw on the squarrel cage shaft.
Old 01-15-2012, 01:43 PM   #4
Sounds like a clogged port on the inducer pressure switch hose nipple or a broken ignitor.
Old 01-15-2012, 01:47 PM   #5
Where do I find the belt? Do I have to remove the motor from the furnace?
Here is the images.
http://imageshack.us/photo/my-images/827/photo3hhs.jpg/
http://imageshack.us/photo/my-images/23/photo2tm.jpg/
http://imageshack.us/photo/my-images/209/photo1gjy.jpg/
Old 01-15-2012, 01:52 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
Are you sure you're hearing the actual blower motor or is it the inducer motor?
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
thone (01-15-2012)
Old 01-15-2012, 02:02 PM   #7
I think what I meant was the inducer motor.
I can see it spinning.
I tried to see if the exhaust pipe is hot, but it is not.
Sorry, if I made it confusing.
Old 01-15-2012, 02:33 PM   #8
Take the rubber hose off the inducer then clear out that little metal nipple that it connects to.
The Following User Says Thank You to Marty S. For This Useful Post:
thone (01-15-2012)
Old 01-15-2012, 02:51 PM   #9
Thanks Marty.
I did it. The metal nipple is pretty clean actually. Do I have to clean deep inside the nipple?
Normally, after I turned the heater on, it would be another "click" after 1-2 mins and it will start to suck/blow the air out.
Old 01-15-2012, 02:56 PM   #10
Hvac Pro
yuri's Avatar
ram a paper clip 1-2" inside that nipple or a small drill bit. also disconnect that hose from the pressure switch and blow it out.
The Following User Says Thank You to yuri For This Useful Post:
thone (01-15-2012)
Old 01-15-2012, 09:54 PM   #11
Marty & Yuri -- Thanks a lot. That solves the problem!
One thing I noticed was that this morning when it didn't work, I don't hear ignitor. Now, I can hear it clearly.
Old 01-15-2012, 10:29 PM   #12
The pressure switch closes via the inducer motor which then allows rest of the heating sequence to begin, the ignitor glows and then the gas valve opens, flames and lastly blower turns on.
No pressure switch, no heating.
Thanks.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Gas Furnace Fan Occassionally Keeps Running After Burner Shutdown Dr_Zoidberg57 HVAC 18 11-10-2010 09:52 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 07:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
