Old 01-24-2008, 10:54 AM   #1
Furnace is making a whistling/humming sound
Greetings all,
I have a filter installed at the bottom of my furnace where the blower fan is located in addition to the normal return filter upstairs.
I've been noticing a whistling sound when the blower is on and when I slide the filter thats near the fan out, the sounds stops. I slide the filter back and the sound returns.
Does this sound indicate my fan may be starving for air? I've been told its just filter noise but I'm not sure. Any thoughts?
Thanks.
JayBird is offline   Reply With Quote
Old 01-24-2008, 02:56 PM   #2
30 year tech
hvac122's Avatar
It sounds like you are starving for return air. Why the 2 filters? What type of filters? Some filters will restrict air more than others. Some restrict way to much.
hvac122 is offline   Reply With Quote
Old 01-25-2008, 01:54 AM   #3
Yes I am starving for return air, My burner was short cycling and the HVAC company closed the hole near the furnace and added it down bottom near the fan. The burner was reaching high limit (too hot) from too small of a return duct. Former homeowner added a second return but wasn't helping. Since the one was added down bottom near the fan the short cycling has stopped. It was a cheap fix, but maybe not the best thing to do. The hole is about 14 x 16 roughly, maybe a tad larger. I wonder if it needs to be bigger??
I use the "mid grade" filters. A little better than the fiberglass but not like the expensive 3M ones
Old 01-25-2008, 08:13 AM   #4
30 year tech
hvac122's Avatar
If I am understanding right the return air was added very near the furnace? If it was added to close it could cause your furnace or water heater to backdraft which is very dangerous. It sounds like you need a pro to size things properly and to do some duct changes so you don't starve the furnace. This will cause premature failure of your furnace and A/C. It is critical to get enough return to the furnace and many are way undersized.
Old 01-25-2008, 10:53 AM   #5
A pro did come out and determined the duct is a little too small. Hot air was having trouble escaping causing the burner to reach high limit and cycle on and off. So yes, an intake was added at the base of the furnace next to the fan and that helped it get the proper air flow and the burner stopped short cycling. Whether it was the best thing to do? I'm not sure but the pros recommended it and they installed it. All he did was cut a square hole in the base of the furnace on the other side, opposite where the main return comes in and I added a filter to it.
Any comment on the slight whistling/humming sound I'm hearing? Is it something I should be worried about? Some say its just filter noise.
Old 01-25-2008, 11:40 AM   #6
30 year tech
hvac122's Avatar
If this is a gas furnace then that is a really bad place to add a return. It would be against code here. If its electric it would be OK. The whistling more than likely means that you are still short on return air and this needs to be fixed. You don't what your furnace to be running at the top of the temperature rise as it will shorten the life. I would call someone that understands ductwork to evaulate your system and give you some options for repair. If its whistling in heating its really going to have problems in cooling as the fan sill be in high speed, if not already.
Old 01-25-2008, 08:47 PM   #7
Its an oil furnace...... The company that came out is a well known company thats been in business for years. I would hope the tech would know better then to install something wrong but then again I'm sure it happens daily. It appears the furnace is getting better air flow because its not short cycling anymore.......thats s plus.
Old 01-26-2008, 09:35 AM   #8
Union HVAC Tech.
A return close to the furnace (oil or gas) can pull in flue gas as well as make the burneer fire imporperly. And is against code many places as H122 stated. Have it piped to another location by another contractor.
A/C operation will just compound the situation and freeeze the coil.
bigMikeB is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Ringing sound from furnace mustanger HVAC 1 12-18-2007 12:53 AM
Soundproof Windows BlueJello General Discussion 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
Furnace making noise munn HVAC 6 02-08-2007 11:25 PM
