Old 11-24-2008, 10:58 AM   #1
furnace making noise
Since we had to turn the furnace on I've noticed a faint beeping sound coming from somewhere within the furnace. It beeps about every 2-3 minutes or so. The furnace is operating properly, no problems with the thermostat, no problems with it shutting off, or anything. As far as I can tell, everything is working fine. The status light on the front of the unit is showing "normal". Also, the beeping only occurs when it is actively blowing warm air. I've thought about maybe it's the motor just squeaking, but it's a no-kidding beeping sound. Any thoughts? And no, it's not an alert telling me to change the filter. I appreciate any help. Furnace is about 5 years old.
ja3118 is offline   Reply With Quote
Old 11-24-2008, 11:51 AM   #2
Another DIY Zombie
I would suggest contacting the manufacturer about this. It may be something as simple as a notification that you need to change your filter.....
Check the troubleshooting section of the IOM.
javan is offline   Reply With Quote
Forced air furnace blowers making noise CowboyAndy HVAC 9 11-26-2008 01:56 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 03:31 PM
Furnace making noise munn HVAC 6 02-08-2007 11:25 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
