Old 11-05-2012, 09:24 PM   #1
Furnace makes clunking noise when starting to cycle
Its a Rheem 90 high effiecincy . when it starts to turn on to cycle, i can hear a few clunky sounds right in the begining. Furnace seems to work fine and blows warm air but the noises seem unusual. it does not have pilot light, so i thinkin it might be the ignition coil thing, but not sure. any ideas? this normal?
straightsix is offline   Reply With Quote
Old 11-05-2012, 09:34 PM   #2
how
When the thermostat first calls for heat, the first thing you'll hear is the inducer motor starting up. Is the clunking sound the first noice you can hear from the furnace starting up?
how is offline   Reply With Quote
Old 11-05-2012, 09:45 PM   #3
sounds like something on inducer motor..thats the 1 st component to start on call for heat...ben sr
Old 11-05-2012, 09:51 PM   #4
Yes it is the first thing i hear when it starts. The noise is normal then?
Old 11-05-2012, 09:53 PM   #5
I'm Your Huckleberry
I've come across a few furnace cabinets that as they expand or contract due to temp differentials the metal cabinets POPS.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-05-2012, 09:53 PM   #6
no its not normal to hear a clunking sound...something is wrong inside inducer motor.
Old 11-05-2012, 10:59 PM   #7
Oh ok. Thanks for the replies. I truly appreciate it
Furnace makes Flicker noise Michigan50 HVAC 7 12-23-2011 07:38 PM
Furnace Air Intake Noise monkeywoods HVAC 1 02-23-2010 05:26 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
furnace making noise ja3118 HVAC 1 11-24-2008 11:51 AM
