Furnace Maintenance - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 02:19 PM   #1
Furnace Maintenance
Hi. I read that its important to service and maintain a furnace prior to putting it into service for the winter season. I know I need to change the filter, vacuum the blower fan, and give a visual inspection. What else needs to be done? Thanks!
daphillenium is offline   Reply With Quote
Old 10-14-2011, 03:07 PM   #2
Rewards Points: 1,668
What kind of furnace: heat pump, gas, oil?
bob22 is offline   Reply With Quote
Old 10-14-2011, 03:19 PM   #3
Oops sorry. Gas
Old 10-14-2011, 04:12 PM   #4
Project Manager
KJINTF's Avatar
Hi
I always try to blow all the summer dust and extra stuff off with a high pressure air compressor, vacuuming from my experience just does not cut the mustard. Then I make sure the blower motor bearings are well oiled. Clean out the insects that have gathered over the several months and hope all is well
Regards
Ken
KJINTF is offline   Reply With Quote
Old 10-14-2011, 04:34 PM   #5
Rewards Points: 6,652
You should change the filters monthly, if you live in an area that there is farming, or you have animals, change the filter at least every 15 days. Also, you should have the system checked twice a year. When getting it ready for cooling, and when getting it ready for heating. As a homeowner, you can do a lot in making sure that your hvac system is running like it should. Everything is in the owner's manual for the unit.
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ HVAC 3 10-30-2010 08:24 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 12:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
