Furnace Lockout And Fan Turning Off Midcycle? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2014, 08:29 AM   #1
Rewards Points: 4
Furnace lockout and fan turning off midcycle?
i have a goodman furnance which is 5 years old. currently there are 2 problems with the furnace.
1. when I set the thermostat to a higher temp and it is showing heat on, the furnace is not starting unless I reset the breaker or furnace switch.
2. When the furnace does finally work, the fan is turning off mid cycle. I can hear the fire, and the blower?? running but not air or very little air coming out of the vents and the temperature doesnt rise.
What could be causing this? Any input is appreciated. I already had 2 different companies come and take a look. They fix something, say its all good.. then its back to the problem again.
tezi777 is offline   Reply With Quote
Old 11-17-2014, 03:20 PM   #2
An old Tradesmen
Rewards Points: 8,176
Blower motor, blower motor run capacitor, or control board.
Old 11-17-2014, 05:52 PM   #3
Rewards Points: 582
what error code are you getting on the blinking light...how many times is it flashing....
Old 11-17-2014, 11:16 PM   #4
Rewards Points: 4
I have no idea where the blinking light is. Where should I look? completely newbie with regards to HVAC here.
Old 11-18-2014, 02:26 PM   #5
An old Tradesmen
Look for a little round window in the blower panel, light will be in there.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (11-18-2014)
