Furnace Limit Switch Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 06:38 PM   #16
An old Tradesmen
Rewards Points: 7,826
Originally Posted by diyheat View Post
No need for the wisecracks in here-I have no use for them people. They just take up space...
Ok, so nothing to do with the limit switch.Auto side not working-manual is...
As I mentioned-call for heat not working, So I began again.
I solved it myself. The problem was the transformer.. it was shorting out. Replaced it for $12....Now, no problem... All works as it should.Thanks to biggles, rep, and how, to put me on the right path.
Thank you for updating us on how you made out.
Old 02-16-2012, 06:40 PM   #17
Originally Posted by yuri View Post
Lennox retro circa 1960's.
Get the torches
hvac5646 is offline   Reply With Quote
Old 02-16-2012, 06:42 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 178
Actually they have the heat exchanger on the 3rd one at our local Lennox distributor, cleaned up and painted nice and silver. Brings back bad memories of removing those old beasts and 200 to 250 gallon oil tanks up narrow stairs in the early 80"s when we got rid of most of our oil and I was strong and smart like Bull.
Old 02-17-2012, 05:50 PM   #19
HVAC Tech/ Browns Fan
Last company I work for service Lennox furnace's that are 50 years old and still running. Customer will not replace it because heat going out of it is very hot and takes care of old Victoria homes. I do remember working on one back then and my jaw dropped. I was afraid it was going to blow up on me.
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
ben's plumbing (02-17-2012)
Old 02-17-2012, 06:10 PM   #20
how
Rewards Points: 1,104
I have a 55 year old armstrong low boy that side by side efficiency tests by myself and UEI have pegged at 82%. One of those scary units that feeds the vent back through the hot and return air plenum on it's way to the chimney.
Yes I check that vent yearly.
Cheap, quiet & trouble free for the 15 years I've been here.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 02-18-2012, 06:08 AM   #21
An old Tradesmen
Don't confuse combustion efficiency with AFUE efficiency.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (02-18-2012), yuri (02-18-2012)
Old 02-18-2012, 12:08 PM   #22
how
Beenthere..
Partypooper
Not confusing anything. AFUE never graced my post. Just responding to the previous post about another oldie but was pointing out that mine burns amazingly clean, has a second heat exchanger and is even older.
Our industry stands on the dogma that new is better, which coincidently is the veiwpoint that pays most of our morgages. From my perch, things are not so black & white and I try to remember that most dogma is a poor substitute for the not so common, common sense.
Old 02-18-2012, 12:20 PM   #23
Hvac Pro
yuri's Avatar
Rewards Points: 178
It also helps that you live in a VERY moderate climate so efficiency is not a big deal. It has got to the point that the gas co who used to do a lot of free basic repairs here won't touch conversion burners in old boilers so like it or not those are going to have to be replaced. Obsolesce gets to everything and everyone. My young techs have never worked on a millivolt system and likely won't get the chance as they are pretty well obsolete. You cannot get cadet fan or limit controls from Honeywell and other parts are going obsolete.
Old 02-18-2012, 12:52 PM   #24
how
My first install of a progamable thermostat on my furnace turned me into a parts changer before I realized I was dealing with a 6 volt system.
Any generic parts I need have not yet become difficult to get but I think your experience is about 20 years ahead of mine.(weather wear factor).
I'm sure we will probably become one of the last bastions of old parts so let me know if you need anything next time that young parts guy gives you that blank stare..
Old 02-18-2012, 01:11 PM   #25
Hvac Pro
yuri's Avatar
Rewards Points: 178
I am going to leave them to their own devices. Freedom 55 or 52 or somewhere in between.
The Following User Says Thank You to yuri For This Useful Post:
Old 02-18-2012, 04:17 PM   #26
An old Tradesmen
Beenthere..
Partypooper
LOL... Bet you can't guess how old my furnace is.
Clue. It was made before modern retention head burners came out.
Old 02-18-2012, 04:47 PM   #27
You heat your home with a campfire?
The Following User Says Thank You to hvac5646 For This Useful Post:
Old 02-18-2012, 06:28 PM   #28
An old Tradesmen
LOL... Not quiet. Its an old old American Standard oil furnace.
Old 02-18-2012, 07:14 PM   #29
Hvac Pro
yuri's Avatar
Rewards Points: 178
Older than this guy? LOL. Actually that is the latest "hot" new furnace in Vancouver. I worked on a bunch of those burning oil (Iron Fireman made oil burners too) as well as stokers I guess and they were AWFUL.
Old 02-18-2012, 07:18 PM   #30
An old Tradesmen
LOL... Not quite.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
High Limit Switch Question pgh HVAC 22 12-12-2010 07:18 AM
reset limit switch on a heil quiet comfort gas furnace hogrider HVAC 1 09-16-2010 06:49 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
