Furnace Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 09:18 PM   #1
Furnace limit switch
Why does limit switch keep going on furnace? I need to buy a new one about once a year (last one was bought Feb 2010). This is Heil gas furnace and it is 19 years old. I've replaced about 1/2 dozen limit switches since I've had this furnace.
jk55 is offline   Reply With Quote
Old 03-02-2011, 10:00 PM   #2
Most likely the duct is to small and the furnace overheats all the time. Limits only cycle on and off so many times before they break. A normal system never needs a new limit.
Old 03-03-2011, 07:09 AM   #3
hillbilly guru
Send a message via Yahoo to hvacguytn615
are you useing the o.e.m parts or aftermarket you can place a thermometer in the duct above the furnace to see what the temp is if it is going over the limit temp you have an air flow problem if not you have a itermitten short or power surge problem
hvacguytn615 is offline   Reply With Quote
Old 03-03-2011, 11:52 AM   #4
how
Rewards Points: 1,070
Is this furnace limit control on the body of the furnace or is it a vent or spill limit control? Are you replacing them with limit controls that have the
same temp ratings as what the manufacture calls for? Is the limit control in a location that could be affected by a cracked heat exchanger?
Anything that restricts the airflow through the system can get it to trip.
A limit control that is tripping on a regular basis is showing you that the system is not operating properly. Having it trip so often that it is breaking says that this is serious and needs more immediate attention.
My last job where this was a consistant problem was tracked back to a factory fan motor running in the wrong direction.
how is online now   Reply With Quote
Old 03-03-2011, 11:59 AM   #5
back to the "factory"?
Why blame the factory? Did they install it? In my book, a blower running in reverse sits with the installer not inspector #12 at the factory.
college A/C is offline   Reply With Quote
Old 03-03-2011, 05:23 PM   #6
how
Blaming doesn't sort out the problem. The furnace just needs to be fixed.
My example was just to show how many different obscure causes can cause limit trips and how we really need more detailed info to try and address it.
Trane limit switch mikethe ductman HVAC 7 01-18-2012 11:46 PM
No emergency cut off switch on my furnace Red Squirrel HVAC 8 10-13-2009 08:09 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 09:35 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
