Furnace Lights Up But Does Not Blow The Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 06:10 PM   #1
Furnace lights up but does not blow the heat
I have a York 80 P3hub16 furnace that is powering up, lights up the "4 torches" but it does not blow in the heat. It takes the typical 30 seconds to begin to blow the hot air but all I hear are several clicks but no blowing. It keeps repeating this cycle of clicks but all in vain. What is going on?
chemike is offline   Reply With Quote
Old 01-03-2012, 06:37 PM   #2
Bad control board, bad motor or bad capacitor. You'll need to see if the motor is getting voltage and test the capacitor to see which it is.
Old 01-03-2012, 06:46 PM   #3
Rewards Points: 578
agree with marty the clicking you here is the relay ..its controled by board need to verify power at blower leads on board to see if relay is working,,,
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump or high efficiency furnace moisheh HVAC 13 11-14-2010 11:59 AM
Gas Furnace, no heat, can smell gas in the crawlspace dr_tunes HVAC 2 12-21-2009 07:37 AM
Furnace lights for only 3 sec robzimich HVAC 1 12-28-2006 10:11 AM
