Furnace Light Going Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2014, 05:24 PM   #1
Rewards Points: 218
Furnace light going off
I came home this afternoon and noticed that the furnace wasn't lit. I turned the power off and on then the burners lit up, but went off after a min. It tired to re-light a few times then stopped. Any idea what is causing this?
joeg679 is offline   Reply With Quote
Old 12-30-2014, 05:38 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 188
Post the brand name and model # and serial # which should be inside the front door. Some pics with the 2 doors off will help.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (12-30-2014)
Old 12-30-2014, 06:26 PM   #3
Rewards Points: 3,892
Does this unit have a diagnostic board on it? Is it giving a code?
Is the air filter clean? Blower running? What fuel? Are any safety's opening?
Also need the furnace info.
roughneck is online now   Reply With Quote
Old 12-31-2014, 07:12 PM   #4
Rewards Points: 332
Send a message via Yahoo to curtd
We had the same problem. Ours runs on kerosene. The tank is located outside. The non pros installed the tank so it was level. It should be tilted so water sinks to lowest point (away from the filter). But since it was level the water ran into the filter and frozened up quite nicely. Had to chisel out the ice and replace the filter. Hair dryer worked to de-thaw the small line between tank and filter.
Also correctly tilt of tank by using a car floor jack and 2x4
curtd is offline   Reply With Quote
Rheem Furnace won't light rheemfurnace HVAC 4 10-08-2016 01:02 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Furnace pilot light will not ignite - Carrier 58 GS Furnace? rasilun HVAC 3 10-29-2011 09:38 PM
Furnace will light - if I hit it! Chuch HVAC 1 10-28-2011 02:05 PM
Weathermaker 8000 gas furnace will not light karyn HVAC 1 01-24-2010 11:17 AM
