Furnace Leaking Water - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 03:36 AM   #1
Question
Furnace leaking water
My furnace is working fine but is leaking a lot of water in my basement. A plumber attached pvc pipes to the furnace and connected it to the drain pipe last year now the leak started again causing a lot of water to leak in my basement. The leak happens when the AC is running.
womanique is offline   Reply With Quote
Old 06-30-2010, 06:09 AM   #2
Condensate drain line plugged up
Old 11-21-2010, 07:45 PM   #3
Question
Water leak under my Furnace ..Help me
Hello
i have a water leak under my Ruud Furnace , it is brand new Furnace and it has been installed in the summer so the leak starts after i start using it in winter.i will attach some pictures..
Furnace leaking water-furnace-20007.jpg   Furnace leaking water-furnace-20002.jpg   Furnace leaking water-furnace-20001.jpg
samerhajjaj is offline   Reply With Quote
Old 11-21-2010, 08:03 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 150
Call the installer back.
Old 11-21-2010, 08:07 PM   #5
could it be the leak from the basement? but i dont see any leak coming from outside
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 10:43 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 12:40 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
