Furnace Leaking Water - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 09:25 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Furnace leaking water
I noticed that on the back of the furnace on the ground the cement gets wet. There's not LOT of water but enough to tell it's leaking. The condensing pipe is ran and there is water that comes out, but I have a feeling not all of it is draining through.
I also had a humifier in the furnace but I removed it and patched the hole. The leaking seems to have slowned down but is still happening. Is this a huge concern? Or would it be excess water from when the humifier was there?
The furnace is a Bryant and is only a few years old.
Old 09-21-2009, 11:02 AM   #2
Newbie Bill
Rewards Points: 520
Is it a higher effeciency furnace?
I know my high efficiency furnace started leaking all over the floor and one of the hoses inside had come undone and some of the condensate was leaking onto the floor. The Tech guy came in and put them back together with a clamp this time.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-21-2009, 11:49 AM   #3
Yes, with the AC on it's likely condensate. The line may be plugged.
Old 09-21-2009, 01:17 PM   #4
Newbie Bill
Rewards Points: 520
Oops, never even considered the air conditioning may still be in use.
Bill
Old 09-22-2009, 12:24 PM   #5
Wire Chewer
Rewards Points: 90
No AC, just heat. I'll open it up and check for a hose. It's not running that much now but once October/November hits it will probably be running way more, don't want water getting on the circuit board or something, depending where it's coming from.
I'll have to check again today, could be what I saw was remains of the dehumifier water, maybe it actually stopped now.
Old 09-22-2009, 03:13 PM   #6
GetYourShineBox's Avatar
It's possible your pvc drain pipe is dirty on the inside and clogging up with a fungus so its not draining properly. if you have a floor drain its possible your drain pipe/tube isnt aligned properly over it so its overflowing.
GetYourShineBox is offline   Reply With Quote
lennox elite furnace leaking water outboardhuy HVAC 10 09-24-2011 10:43 AM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 12:40 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 06:22 PM
