Furnace Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 12:51 PM   #1
furnace leaking
i have a lennox furnace model C23-41WFC-1 that is leaking very heavy from arrow in pic when the ac kicks on. whats the best action plan to stop it?
wd45gto is offline   Reply With Quote
Old 07-17-2011, 12:58 PM   #2
check the drain, its probably plugged and the condensation isnt draining out.
Old 07-17-2011, 12:59 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 380
need to dismantle that fitting where it comes out of the coil and clean the debris out of it. I don't like glued joints like that for that reason. I would convert it to a clear hose and connect that to the drain pipe with hose/gear clamps and put a new fitting on the coil. get a Pro to do it if you don't know how.
Old 07-17-2011, 02:37 PM   #4
thanks, that was it. cut out the old and replaced it with a clear tube.new fittings and 4 ft. of tube about $8.50.
thanks again
ray
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Luxaire Gas furnace leaking water johns811 HVAC 8 01-25-2010 06:26 AM
Burnham V-7 furnace leaking water Fastlane HVAC 7 11-29-2008 07:34 AM
Water leaking from Heil gas condensing furnace BlueStar HVAC 5 11-23-2008 05:47 AM
