Furnace Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 05:27 AM   #1
Furnace Leak
high all, new homeowner here. Noticed over the weekend that my furnace was leaking water all over the place. Trying to find out what the problem is. there is a humidifier attached. There is a black tube running from the humidifier connected to pvc pipe going to the furnace. Right where the black tube and pvc pipe meet is where the water was spurting out. Anyone know what could cause this. Thanks.
elboogie09 is offline   Reply With Quote
Old 01-17-2012, 06:06 AM   #2
Welcome to the site and home ownership. Yes drains get plugged from gunk that grows in the stale water. Usually 3/4" pipe is easy enough to blow the obstruction out.
The Following User Says Thank You to Marty S. For This Useful Post:
elboogie09 (01-17-2012)
Old 01-17-2012, 07:52 AM   #3
This is all new to me. Just a little more clarification on the 3/4" pipe would be greatly appreciated. Is this something really simple? Thanks.
Old 01-17-2012, 07:54 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
post some pics of it. remove the black pipe and carefully pour some bleach/javex/clorox and water in there and flush it.
The Following User Says Thank You to yuri For This Useful Post:
Old 01-17-2012, 08:36 AM   #5
I tried posting a pic, but the file was to large. I will try again.
Old 01-17-2012, 08:41 AM   #6
Here is a pic.
Old 01-17-2012, 09:10 AM   #7
the white PVC pipe is plugged. You may have to blow it out if you can't do it by hand.
An air compressor .. or the exhaust of a shop vac would work.
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
Old 01-17-2012, 09:15 AM   #8
I'm Your Huckleberry
Rewards Points: 2,270
or if you have strong lungs..
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 01-17-2012, 09:17 AM   #9
Thanks everyone for the replies!!! I see this is going to be a fun process.
Old 01-17-2012, 09:20 AM   #10
Ugghh.... I got a mouth full of stagnate water once doing that..but if you have nothing else to work with , yeah you can blow it out by lung power.
I always wrap a clean rag or paper towel around the tube before trying.
Old 01-17-2012, 09:24 AM   #11
How is the black tube attached to the pvc pipe? Can I just pull it out. I actually have access to an compressor. Not sure if it works, but blowing would be a last resort.
Old 01-17-2012, 09:24 AM   #12
Hvac Pro
yuri's Avatar
pure bleach will eat the heck out of any gunk. make sure you don't breathe in the fumes or get it on your hands. or you can hire a pro for a $99 service chg and $70 - $150 for a drain line clearing procedure. looks like it just sits inside that elbow. U should pull the cover off that hum and check inside as it may need a new evap cell and clean the trough it sits inside.
Old 01-17-2012, 09:26 AM   #13
Thanks for pinch hitting for me Yuri
Old 01-17-2012, 09:29 AM   #14
Hvac Pro
yuri's Avatar
at least when I go to unplug an ac evap coil I spend more than 5 mins for some jiggy jiggy on the fitting with a bottle brush and chg the guy $200 to do it (like some guys do). I check the freon for "free" so they feel better and who knows you may get a sale if it is a leaker.
Old 01-17-2012, 09:42 AM   #15
Yuri
I agree. If you unplug the ac drain you are just asking for it if you don't put the gauges on the unit. More time than not the unit needs some good maintenance and that is always beneficial to the HO and the bottom line.
American Standard 90%HE Gas Furnace leaking gas blueydgal HVAC 1 10-30-2011 02:26 PM
Is it leak from the basement or from The Heater? samerhajjaj HVAC 9 11-23-2010 10:13 PM
Water leak on gas furnace exhaust PCV pipe scairns HVAC 7 11-22-2010 09:06 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
