Furnace Keeps Turning On Evey 5 To 10 Min. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 09:10 AM   #1
Question
Furnace keeps turning on evey 5 to 10 min.
the furnace keeps turning on even when the temp on the thermostat does not change. we just installed a new 7 days digital thermostat.
Annette99 is offline   Reply With Quote
Old 11-28-2010, 10:05 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
most digital stats are setup for a 1/2 degree swing, meaning that the temp will not change on the stat, but its actually 1/2 degree cooler than setting. It is fine that the stat doesn't change temps, that means its working properly so you don't get hot and then cold and then hot again. All is ok!
hvactech126 is offline   Reply With Quote
Old 11-28-2010, 10:20 AM   #3
As stated that's the way they work. If yours has an adjustable CPH then change it to a lower number. Still going to display the same temp but will give a greater droop between cycles.
Old 11-28-2010, 10:33 AM   #4
An old Tradesmen
Rewards Points: 7,816
Yep. Sounds like its doing what it is suppose to do.
Depending on brand and model. You can set the CPH lower to lessen the cycles. And some can have the temp drop increased.
Old 11-28-2010, 01:00 PM   #5
Thanks for the explanation. Makes sense.
Much appreciated-feel better now
Old 11-28-2010, 01:07 PM   #6
Rewards Points: 6,652
Also, if you furnace is a 2 stage unit, and the thermostat is set up properly, it will also cycle the furnace at the lowest stage to keep it comfortable. What model of Furnace & thermostat?
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
HELP!! My thermostat isn't turning my furnace off!! Mac Danny HVAC 14 12-29-2008 11:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Turning down furnace burners? Squire HVAC 3 11-17-2007 08:53 PM
