Furnace Intallation - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2009, 07:15 AM   #1
Furnace intallation
Iím looking into replacing my 20+ year oil furnace but so far Iím very confuse with contractors not giving me the story on what needs to be done. One claims that the pipe going from the furnace to the chimney is to long (about 10í) so the furnace needs to be moved and another one the furnace is find where it is but the liner of the chimney need to be change because there is an increaser at the entrance of the chimney from the pipe. Can someone direct me where I could find the rules and regulations for that kind of stuff? I live in Ontario.
Also just for your info the chimney liner and the pipe (double wall) was changed 4 years ago.
TS37 is offline   Reply With Quote
Old 08-28-2009, 07:40 AM   #2
It sounds like you are pursuing an 80% efficient furnace.
Since you have a new liner I would assume it is sized right, but could change with size of new furnace.
Being ten foot from a wall in my area (not far from Ontario) with double wall vent should be ok. I would need size of new furnace check the size issue.
Get me the new furnace btu rating and diameter of existing liner.
Cheers,
Manhunter
manhunter is offline   Reply With Quote
Old 08-28-2009, 07:45 AM   #3
Get two estimates
Old 08-28-2009, 08:43 AM   #4
I got two estimates so far (will be getting at least 3 more) both only quoted the work that will be done with the price and yes I'm looking for a 83% or better
I will get the info you required (btu, diameter ...) in the next few days and post them here.
Thank you
Old 08-28-2009, 12:22 PM   #5
HVAC / Plumbing
get the price of a 90+ vs the 80%.. May not be that much more. may be less because they may not have to move the furnace, adjust add duct work, vent, etc,
kenmac is offline   Reply With Quote
Old 08-28-2009, 12:31 PM   #6
An old Tradesmen
Rewards Points: 7,746
Condensing oil furnaces can cost more to maintain then they save.
Old 08-28-2009, 01:51 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 92
I would be leery of them. Always a bit of sulphur in the smoke which will be in the condensate? turn into sulphuric acid?eat the condensing coil? Have never seen one so I may be wrong, just theorizing.
Old 08-28-2009, 01:53 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 92
TS37, have you checked with Ontario Hydro about the cost to heat your home with electricity, or electric furnace and heat pump VS. oil. It is a lot cheaper to go electric in Manitoba, oil is ridiculously expensive.
Are you looking for a new oil furnace or converting to gas?
Old 08-28-2009, 03:03 PM   #9
An old Tradesmen
More trouble with the secondary HX clogging, then rotting out.
Some of them need to be cleaned twice a heating season.
If the nozzle starts to lose just a little of its spray angle, they soot up real quick.
Worked on a couple of them. PITA
Old 08-28-2009, 03:09 PM   #10
HVAC / Plumbing
My bad,,,,I missed the oil part... I saw 80% funace
Old 08-28-2009, 04:02 PM   #11
Estimates
Thank you
People don't get enough estimates get a whole page full why not they are free and besides that pick their brains while your at it.
Make sure they are insured (look at insurance certs). Make sure you get referrals and call them( possibly look at the work). Sounds like a couple rip offs to me.
SULTINI is offline   Reply With Quote
Old 08-28-2009, 04:30 PM   #12
Gentlemen, the topic of oil was never raised as far as I have read.
Old 08-28-2009, 05:05 PM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 92
Welcome aboard Manhunter.
Beenthere is our most knowledgeable oil guru (I used to do oil years ago) and it sounds like they make high efficiency condensing oil furnaces/over 90%. There is no 83% efficient gas furnace. Sounds like there is confusion over which fuel our poster is burning.
Found one:http://www.adamsmanufacturing.com/products.html
Old 08-28-2009, 05:21 PM   #14
An old Tradesmen
From original post
I’m looking into replacing my 20+ year oil furnace
Although he didn't say hewas staying with oil. His current is oil.
Unless he meant to say 20+ year old furnace.
Old 08-28-2009, 05:32 PM   #15
Very good.
But with in the US the highest level of efficiency that may be achieved is 83%.
Of course the actual operational efficiency is below the 83% number to avoid internal condensation which would destroy the insides of the furnace. Many years ago HVAC operator-owners were presenting 80% models as 83%- whether thru ignorance or fraudulent intent. The 83% number has persisted in some areas of the US.
That, at least is what I bring away from it.
Cheers
Lennox Furnace G27M Series Ė Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
