Old 11-28-2008, 11:27 AM   #1
Question
Furnace installed. Intake from outside. DO i need it?
I recently had a furnace installed. The salesman said he would have them put in an intake from the outside because there wasn't one. It's an 80% efficient furnace, older home, but the mechanical room is semi enclosed in its own room. When the salesman was selling me the unit, he said 'these older homes like yours breathe good on their own and probably don't need an intake from outside, but we will put one in anyways'. It is on the service order when he sold me the unit, but when they installed the furnace i guess he said it would be too hard to put in. I told him okay and now i am rethinking it and might have him put the intake vent pipe in from outside.
Northland101 is offline   Reply With Quote
Old 11-28-2008, 11:36 AM   #2
hvaclover's Avatar
Should have gone 905, but that's water under the bridge now.
If the mechanical room is with a door that you keep closed, then a combustion air vent is necessary. If on the other hand there is no door and the basement area it draws air from to burn, then it won't be needed.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 11-28-2008, 11:37 AM   #3
hvaclover's Avatar
Should have gone 90%, but that's water under the bridge now.
If the mechanical room has a door that you keep closed, then a combustion air vent is necessary. If on the other hand there is no door and the basement area it draws air from to burn, then it won't be needed.
Old 11-28-2008, 11:46 AM   #4
the room has 3 plastic like folding doors on 3 of the 4 sides of the room. Another wall has no door. And there is a little gap on the bottom of the doors
Old 11-28-2008, 12:21 PM   #5
hvaclover's Avatar
Unless the Bi-fold doors are ALL louvered, then you need the combustion air duct.
Old 11-28-2008, 03:03 PM   #6
tk03's Avatar
This is a calculation for combustion air. You can calculate it yourself to determine the need of or not.
http://www.comfort-calc.net/Combusti...lculation.html
tk03 is offline   Reply With Quote
Tags
hvac air intake furnace
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
